Is there a CSV (Tab Separated) Writer Option?
  • Nov 25, 2019 9:43 PM UTC
  • 279 views
benvk
Forum|alt.badge.img+8
I have a user that requires a non-spatial SQL Server Table provided to them as a Tab Separated CSV file. I have found the CSV writer, but cannot find an option to output as tab separated instead of the Comma Separated.
Does anyone know if this is possible?
Thanks very much for your time.
Cheers
Best answer by bwasserstein
Add a "CSV (Comma Separated Value)" writer. Under parameters, use the drop-down to change the delimiter to "tab".
That should do it for you. Cheers.
bwasserstein
Participant
  • Participant
  • Nov 25, 2019 9:48 PM UTC
benvk
  • Nov 25, 2019 9:52 PM UTC
thanks so much, I am such a n00b, I was double clicking the writer in the layout window, I didnt even think to look in the Navigator for the option!
Thanks heaps :)
