Is it possible to translate from AutoDesk Recap to I3S using FME?
  • November 21, 2019
  • 35 views
fmelizard
Forum|alt.badge.img+19
I have an AutoDesk Recap Mesh file(.rcm extension) is it possible to translate this to an Esri I3S file using FME Desktop?
trentatsafe
  • November 21, 2019
While it is not possible to read the AutoDesk Recap Mesh file natively in FME, there is a workaround that can be done. In AutoDesk, there is an option to export the Recap Mesh file as an OBJ file. If you can get a hold of the .rcm file along with the OBJ export, the attached workspace will allow FME to position and generate an i3s file based on that Obj/rcm file.
The attached workspace should be set up to point at a directory of OBJ files and their Recap Mesh files and output to a i3s file.
