The scenario is
The ask how can i eliminate to read from row 1. The attributes that I intend to process is
No, Name and ID
If reading from an excel file, you can select the field names row and the cell range
Hi @aashnaparikh , when you add the reader, you can adjust this in Parameters.
Then here you can change Field Names Row from 1 to 2
And normally you will obtain this :
22 votes
21 votes
16 votes
8 votes
6 votes
5 votes
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
