Is it possible to convert .obj files to .dwg files?
  • Jun 10, 2021 9:50 AM UTC
  • 377 views
Dear FME community,
I would like to know, if it is possible to convert a simple .obj-file into a .dwg-file. dwg is the standard for Autodesk AutoCAD. AutoCAD is not able to open .obj files.
Originally I had gml/ cityGML and .xyz-files which I converted to . obj-files. If there is no way to convert .obj directly into .dwg, maybe it is possible to convert gml/ cityGML and xyz-files into .dwg-files.
I would be very happy if you could give me any hints.
Thank you very much in advance!
Christian
muzhnasto
Forum|alt.badge.img+12
  • Jun 24, 2021 5:49 PM UTC
Hi. Try use FBX format
