Is it posible to create esri file geodatabe with DATASETS with Esri Geodatabase (File Geodb Open API)
  • Jun 6, 2024 5:40 AM UTC
  • 107 views
proteve
Forum|alt.badge.img+4
Title!
i’m trying to import shp files into a gdb database in separate dataset based on the folders that the shape files are located. i know i’ve read somewhere in the help to set dataset/feature name for feature name but its not workig.i get an error that its not possible without coordinate system. so i’ve added coordinate system to writer but i still get the same error.
the error is
FileGDB Writer: Cannot currently create feature datasets with unknown coordinate systems. Please specify a known coordinate system, or do not write to a feature dataset. Failed to create feature class 'B10/Shape_Z'
so is it possible to write datasets in esri geodatabae with  Esri Geodatabase (File Geodb Open API) writer? if so can you post an example.
proteve
  • Jun 7, 2024 7:53 PM UTC
well i manage to solve the problem.
now i have some problem with some missing entries.
