Is a dash in an ArcGIS Server Feature Service URL a no-no?
  • Jun 5, 2018 10:38 PM UTC
  • 5 replies
  • 118 views
aaron
Forum|alt.badge.img+12
I am trying to add an ArcGIS Server Feature Service reader to my workspace but get the following error when I click to get the Layer List: Python Exception <HTTPError>:401 Client Error: Unauthorized. I suspect the issue is a dash in the URL, which goes something like https://server-new/arcgis/rest/services/MyMapService/MapServer. I can't add any of the map services from this ArcGIS Server. However, we have several other ArcGIS Server environments and I don't get the error with any of them (and none have dashes in their names). Could the dash be the issue? (FME Desktop 2016.1 - build 16492)
Thanks,
Aaron
  • Jun 6, 2018 7:37 AM UTC
Is the dash in the server-name as in your example? If so, I don't think that should be the issue.
aaron
  • Jun 6, 2018 3:30 PM UTC
Yes, the dash is in the server name as in the example above. I have six other ArcGIS Server environments, no dash in the server names, and have no issues. The environments are configured pretty much the same. Other than the dash, I don't know what the cause of the error might be. I'm open to suggestions.
  • Jun 7, 2018 9:02 AM UTC
I'm using FME to read from several ArcGIS Server instances (Feature Services) with multiple dashes in the machine name, I've never encountered any problems in that regard.
I would suspect the problem to be elsewhere.
aaron
  • Jun 7, 2018 4:41 PM UTC
Thanks for the info @david_r. I will look elesewhere for the cause.
runneals
Forum|alt.badge.img+32
  • Dec 19, 2018 7:19 PM UTC
This issue occurs on ArcGIS Online, which I suspect might be similar to the issue that you're having. It seems like it's an authentication issue. Are your services secured or completely public? https://knowledge.safe.com/questions/57120/error-reading-arcgis-online-agol-feature-layer.html
