Interpreting IFC_XML in FME
  • Jul 27, 2018 10:28 AM UTC
  • 60 views
I am looking into the possibilities to proces IFC_XML messages within FME. I found that the current IFC and Revit readers are not able to read IFC_XML files.
One approach is to build a custom reader / transformer / workspace to interpret IFC_XML messages. I think it would be a lot of work to make a custom implementation of the IFC_XML standard in FME. Especially difficult to interpret the geometry of the objects.
Another approach would be to use a third party tool (e.g. python library). But i am struggling to find something appropiate. I have only found xBIM Toolkit so far (which is .NET based). I am playing with the idea to see if I can use this tookit to create custom IFC_XML transformer in FME.
I would like to hear from others who are experienced with using this format. How would or have you tackle(d) this?
deanatsafe
  • Oct 10, 2018 7:21 PM UTC
I recently posted an IFC XML custom reader for ifcSpaces to FME Hub here: https://hub.safe.com/formats/ifcxml-ifcspace-reader
This is meant more of a starting point to show one approach for extracting geometry from IFC XML. For a more comprehensive solution, we are working on a full featured IFC XML reader hopefully for FME 2019.
jneujens
  • Oct 11, 2018 10:52 AM UTC
That's a really interesting starting point to check indeed!
