IFC: how to write custom property sets and data?
  • Apr 12, 2018 2:14 PM UTC
  • 349 views
I need to write attributes in a custom tab, basically like any of the blue tabs that can be seen here:
(the viewer used is Solibri MV; the model is the top example found here: http://www.ifcwiki.org/index.php?title=KIT_IFC_Examples ). I've tried the AttributeCreator, but the property set doesn't even get written. The method however does work, as standard properties like Identity Data do end up in the IFC:
I also tried the IFCPropertySetDefinitionCreator, but this doesn't produce any empty propety set either (nor do I know how to write values to it). Can FME even write custom attributes?
Best answer by daveatsafe
Hi @clickingbuttons,
The following article illustrates how to create custom property sets in IFC:
AutoCAD to IFC Conversion
daveatsafe
Forum|alt.badge.img+24
  • Apr 12, 2018 11:04 PM UTC
Great, this helped a lot. For some reason I couldn't write feature attributes directly. I had to use new names. E. g. if I had an attribute called "FloorCount" I couldn't just use "FloorCount" in the IFCPropertySetDefinitionCreator and then use the original attribute as source in the GeometryPropertySetter. Instead I prepended an underscore "_FloorCount" in the creator and then created a corresponding attribute and linked it with the original FloorCount attribute.
  • Apr 30, 2019 2:36 PM UTC
Hello @daveatsafe
What are the chances of getting a dedicated video, or maybe even a webinar just for IFC usecases?
I looked at all your articles, that helped a lot, but I still feel like a complete dummie.
chrisatsafe
Hello @daveatsafe
Hi @ras,
There are a couple of IFC webinars featuring @daveatsafe with sample workspaces on the Webinars page that might be helpful:
