I want to saperate out jpg files from a folder into another folder querying based on character present in jpg file names. For example of any file has Character "A" then those files should be copied to my output folder.
  • Mar 13, 2018 6:27 PM UTC
  • 136 views
Details :
I tried to add Dataset & Pathname reader followed by StringSearcher, FeatureReader and writer as format JPEG.
I am getting desired output till feature reader , when i checked with logged but i am not getting files in output folder.
  • Mar 13, 2018 6:32 PM UTC
attache4d is the WB created path2jpeg.fmw
todd_davis
Forum|alt.badge.img+23
  • Mar 13, 2018 8:11 PM UTC
You can do all this with a Jpeg Reader.
Choose the Jpeg reader and under the "Dataset" select the drop down on the far right. Choose "select Multiple files/folders". Then add the relevant folder. In your case you are trying to find jpegs contain B, so the filter needs to be *B*.jpg.
ekkischeffler
Forum|alt.badge.img+7
I would keep using the "Directory and File Pathnames"-reader: This will get you a file listing of all *.jpg and you can use the 'path_rootname' attribute in a Tester to filter relevant files. Then use the "File Copy" writer to copy the images to the desired folder instead of reading all JPGs.
