i m trying to create the before delete trigger to execute the following
  • July 16, 2018
  • 20 views
CREATE OR REPLACE TRIGGER invoice_before_delete BEFORE DELETE ON prj_invoice_work_exe FOR EACH ROW DECLARE v_username varchar2(10); BEGIN SELECT user INTO v_username FROM dual; INSERT INTO prj_invoice_work_exe1 ( PIE_PIN_ID,PIE_TDT_ID,PIE_ID,PIE_QTY_EXECUTED,PIE_UNIT_PRICE,PIE_NET_PRICE,PIE_INVOICED_AMOUNT,PIE_UNT_CODE,PIE_HST_UNIT_PRICE, PIE_HST_TOTAL_QTY,PIE_HST_TOTAL_BILLED_QTY,PIE_HST_ALLOW_TO_BILL_QTY,PIE_HST_PRCT_OF_COMPLETION,PIE_HST_QTY_COMPLETED, PIE_PWR_ID,PIE_DISCOUNT,PIE_DOWN_PAYMENT_RECOVERY,PIE_BOQ_DISCOUNT,PIE_BOQ_DOWN_PAYMENT,PIE_UNT_PRICE_BFR_DISCOUNT, PIE_TOTAL_PRICE_BFR_DISCOUNT ) VALUES ( :old.PIE_PIN_ID,old.PIE_TDT_ID,old.PIE_ID,old.PIE_QTY_EXECUTED,old.PIE_UNIT_PRICE,old.PIE_NET_PRICE,old.PIE_INVOICED_AMOUNT,old.PIE_UNT_CODE,old.PIE_HST_UNIT_PRICE, old.PIE_HST_TOTAL_QTY,old.PIE_HST_TOTAL_BILLED_QTY,old.PIE_HST_ALLOW_TO_BILL_QTY,old.PIE_HST_PRCT_OF_COMPLETION,old.PIE_HST_QTY_COMPLETED, old.PIE_PWR_ID,old.PIE_DISCOUNT,old.PIE_DOWN_PAYMENT_RECOVERY,old.PIE_BOQ_DISCOUNT,old.PIE_BOQ_DOWN_PAYMENT,old.PIE_UNT_PRICE_BFR_DISCOUNT, old.PIE_TOTAL_PRICE_BFR_DISCOUNT, sysdate, v_username ); END; /
and it shows the compiling error!
Trigger INVOICE_BEFORE_DELETE compiled LINE/COL ERROR --------- ------------------------------------------------------------- 6/4 PL/SQL: SQL Statement ignored 6/16 PL/SQL: ORA-00913: too many values Errors: check compiler log help me to solve this issues.
  • July 16, 2018
You have specified 22 field names in the INSERT statement, but given 24 values, so it's a SQL syntax error that needs to be fixed.
Generally speaking, if the error message contains an ORA-xxxxx code, it's almost never an FME issue.
