I'm looking to summarize similar feature classes contained in an ESRI File Geodatabase. I am simply looking to write out counts of features appearing to excel and possibly summarize these. I have tried using the attribute pivoter with no luck.
  • Nov 5, 2020 3:55 AM UTC
  • 96 views
In FME, I have a File Geodatabase Reader (merged feature type). I would like FME to group features by fme_feature_type and output each feature type to a port.
I have gotten close with the attribute pivoter, but haven't had any luck writing counts.
Does anyone have any suggestions?
What I'd Like to accomplish:
Untitled
Almost got it with attribute pivoter:
Screenshot 2020-11-03 131729My settings for attribute pivoter:
Screenshot 2020-11-03 131748
Thank You
Best answer by ebygomm
Statistics calculator for stats
Read all feature classes and expose fme_feature_type
Statistics calculator with group by on fme_feature_type
bwn
Forum|alt.badge.img+26
  • Nov 5, 2020 10:22 AM UTC
A generalised approach is:
1. Dynamically read all Feature Classes to a single Generic Output Port, and expose fme_feature_type
2. Send the output of this to Counter: Set Counter Name to @Value(fme_feature_type). This will count how many features are in each feature class
3. Send the output of this to Sampler. Group By: fme_feature_type. Set Sampler to read the last 1 feature . This will output 1 feature per feature class, with the Counter Attribute on this Feature being the Total Count of the features in the feature class
FME kinda takes some mental adjustment in that sometimes our old SQL, Grouping/Pivot methods are sometimes unnecessary for getting Stats!
Forum|alt.badge.img+54
  • Nov 5, 2020 10:57 AM UTC
  • Nov 29, 2020 1:08 AM UTC
This worked great. Thank you!
  • Nov 29, 2020 1:11 AM UTC
Awesome. Just what I needed and super simple to use. Thank You!
