How to translate Access select query to FME?
  • Apr 26, 2016 3:19 PM UTC
  • 89 views
Hi all,
I'm trying to translate an Access select query to a FME script.
I have two Excel files in Access: one that contains data (LINC_RawData) and a comparison file (Linc_Recoding_Scheme)
Below select Access query shows records that have a value in the "Category" field and that do not have a value in the "UID" filed.
How can I translate this to FME?
Basically, all data should flow through to a writer except when it matches above query, I'd like it to appear in a separate output (or list / filter)
Thanks,
Ed
Best answer by david_r
Hi
The FeatureMerger can do it for you. Direct the "LINC_RawData" to the Requestor and the "Linc_Recoding_Scheme" to the Supplier. Merge on Category = UID.
If I've understood you correctly, you'll get what you need coming out of the NotMerged port, which you can then send to a suitable Writer.
David
  • Apr 26, 2016 8:12 PM UTC
Hi
David
  • Apr 29, 2016 7:59 AM UTC
David, thanks for your comment. The FeatureMerger did the job, thanks!
Best
Ed
