How to transform email json to other file
Good day!
I have an issue with reading email messages. We plan to utilize an information about vessels (some information and current location). Contractor provides this information in email message. Looks like simple message in email:
As a result of process this email content in WB i have next table:
But i don not need data in excel table (it's only for test). Result should be a shape file and all attributes should be stored in separate columns where (for example) vessel_name is column name and Vinsky Star is value...that is for all records.
How i can do it?
Thanks before hand)
  • May 24, 2016
Hi
You can use the AttributeSplitter to first split individual lines, then splitting on ": " to get the key/value pairs.
David
  • May 25, 2016
david_r wrote:
Hi
David
I agree that the AttributeSplitter is a quick way to split each line into key and value, if every separator colon is always followed by a space. However, I found an exception in the data. In this line, there wasn't a space between the colon and following string.
Mailto:vessel.tdp@de.com
If it's not a typo, the StringSearcher with this regex might be better.
^([^:]+)\s*:\s*(.*)
  • May 25, 2016
^([^:]+)\s*:\s*(.*)
Or just split on ":" and then use an AttributeTrimmer :-)
  • May 25, 2016
^([^:]+)\s*:\s*(.*)
I also thought so, but...
Position date & time: 2016-05-20 04:01:33
:-0
  • May 25, 2016
:-0
Whoops. Regex it is, then...
  • May 26, 2016
@david_r, @takashi
Gents, many thanks!)
