How to transfer a UUID fiels from Excel to Oracle Raw field.
  • Jun 13, 2019 9:16 AM UTC
  • 18 replies
  • 380 views
I'm reading an Excel file with UUID fields looking like this {c52aff68-61fb-4004-bd58-84a3eb35e878}. How do I transfer them to an Oracle raw(32) fields in the Writer?
itay
Forum|alt.badge.img+19
  • Jun 13, 2019 9:31 AM UTC
Hi @fritspoulsen12
Maybe @david_r comment on using SQL in this post https://knowledge.safe.com/questions/3309/write-uuid-to-oracle-raw-field.html can help you.
  • Jun 13, 2019 9:38 AM UTC
Oracle uses a different (slightly non-standard) way of representing UUIDs compared to most other software. Basically you'll have to transform the ISO UUID to the Oracle equivalent by transposing character groups.
You can either do this using some Oracle helper functions that I posted here:
Or you can use a PythonCaller in your workspace with something like this:
def iso_to_ora_uuid(feature):
    iso_uuid = feature.getAttribute('my_uuid')
    if iso_uuid:
        iso_uuid = iso_uuid.replace('{', '').replace('}', '').replace('-', '')
        ora_uuid = iso_uuid[6:8] + iso_uuid[4:6] + iso_uuid[2:4] + iso_uuid[0:2] + \
                   iso_uuid[10:12] + iso_uuid[8:10] + iso_uuid[14:16] + \
                   iso_uuid[12:14] + iso_uuid[16:21] + iso_uuid[-11:]
        feature.setAttribute('my_uuid', ora_uuid.upper())
This will transform the attribute my_uuid from ISO to Oracle RAW format.
  • Jun 13, 2019 9:40 AM UTC
    if iso_uuid:
Quick tip: I also use this handy little "calculator" quite a lot for one-off conversions:
https://robobunny.com/cgi-bin/guid
  • Jun 13, 2019 12:51 PM UTC
Useful that !
Thx guys, David-r's idea using the PythonCaller seems perfect for me. However, I can't make it work.
Can anyone show me, how to set up the PythonCaller parameters correct?
The FME template for the caller looks quite different, so I'm a bit confused (don't know Pyton at all) on how it should look.
  • Jun 19, 2019 9:30 AM UTC
Have a look at the attached FME template workspace (FME 2018.1)
iso_to_ora_uuid.fmwt
Thx a lot, David. Sometimes it's much easier, than you think. The FME template completely confused me.
  • Jun 19, 2019 9:48 AM UTC
Good to hear it helped.
I understand why the default Python code template can be confusing to new users, fortunately the documention for the PythonCaller does a good job of explaining how it works.
Hi again, Been working with David-r's use of the PythonCaller. But I'm confused on the result when putting the generated UUID to the Oracle RAW-field.
The original GUID looks like this: {c52aff68-61fb-4004-bd58-84a3eb35e878}
After the PythonCaller like this: 68FF2AC5FB610440BD5884A3EB35E878
So far, so good, but in the Oracle RAW-field like this, like normal char-codes: 3638464632414335464236313034343042443538383441334542333545383738
Is that really, how it's supposed to look in a RAW-type Oracle field or do I need further conversion??
  • Jun 19, 2019 1:44 PM UTC
You should use the HexToRaw() function to cast the FME string to a proper Oracle RAW value.
If you have this Oracle UUID as a string:
Then the SQL statement to insert it into Oracle could look like this:
insert into my_table (my_uuid) values (hextoraw('68FF2AC5FB610440BD5884A3EB35E878'))
@David_r. Can I do that in FME genericly using AttributeCreator or SQLExecutor?
  • Jun 19, 2019 2:06 PM UTC
Yes, definitely. Example in the SQLExecutor, if your UUID string is contained in the feature attribute my_uuid:
values (hextoraw('@Value(my_uuid)'))
Notice the single quotes and that there is no semi-colon at the end.
@David'r, That's great, but can't I do the conversion earlier, before the actual insert, and then just get the field inserted automatically vie the FME Writer together with all the other fields?
  • Jun 20, 2019 6:51 AM UTC
That should work, yes. If it doesn't, please post a minimal workspace here + logs to reproduce the issue.
@david_r. Thx again. It now works with the SQLExecutor Insert.... method. I never really tried in AttributeCreator, but it seems it does not know the HEXTORAW function, but no problem now.
  • Jun 21, 2019 12:03 PM UTC
HEXTORAW is an Oracle-specific function and wouldn't make much sense outside that context, which is why it only works in the SQLExecutor.
@david_r. Thx again. For me, that's one of the main problems in using FME. To know when you use an unknown illegal function or just have the wrong syntax for using it correct in FME.
  • Jun 21, 2019 12:17 PM UTC
No worries, we all have to start somewhere. Just keep asking questions :-)
