How to specify the feature type in the FeatureReader
  • Jan 24, 2014 10:26 AM UTC
  • 6 replies
  • 85 views
Hi
I have a huge set of Las files and I just want to pick out one or more of the files and cut out a pre-defined area. The area will be defined by the user, a published parameter. I do area on area overlay, the customer defined area over a square grid to catch one or more id numbers. Know I drop the geometry and just use the attribute in this part of the workbench. Couse I figured it would take longer time to do a spatial intersection in the next part of the workbench.
I use the feature reader transformer and specify the feature type to read to the attribute above (Id number).  I have defined the directory and dataset is set to *.las. I’m having problems though when I run the work bench it doesn’t fetch the Las files. The attribute is defined as 70875_7620 so I tried 70875_7620.las and no deferens.
THe transformer runs when I use the spatial intersection mode that’s way I figured out it  must be the attribute.
Any Ideas?
Tofia
Best answer by gio
Using a binarygrid i do following.
-With the area of interest i select the index required wich in my case is BLADNR. (in your case this yields the ID_number(s)).
-I do a dynamic feature reader on the binary grid (in my case i.e.
"H:\\My Documents\\AHN2\\ahn2_05_ruw\\geogegevens\\raster\\30f\\**\\**")
On this i expose fme_basename.
then a featuremerger on (in my case)
requestor:  fme_basename and suplier: BLADNR
your case would be requestor: fme_basename and suplier: ID_number.
You dont need a parameter, just a dynamic feature reader.
fmelizard
Forum|alt.badge.img+22
  • Jan 24, 2014 10:36 AM UTC
I suspect it has to do with the fact that it is a parameter, which is not known when executing.
Itay
  • Jan 24, 2014 10:58 AM UTC
Thank you for the fast answer!
The Id number for the grid is just un attribute and it´s selectable in FeatureReader transformer am not shore thought how the feature type attribute string itself should be written I could use the concatenater and write the hole address but that seems wrong.
My settings:
Dataset: "K: \\Sofia\\NNH\\Test_las\\*.las"
Attribute: ID_number (example 70875_7620)
Select all features (no spatial test applied)
Keep result attributes and geometry only.
Tofia
fmelizard
  • Jan 24, 2014 12:00 PM UTC
In that case have you tried specifying the attribute in the "Query the feature types specified in the attribute below" ?
Itay
  • Jan 24, 2014 12:25 PM UTC
Yes that’s where the attribute ID_number is specified
I figured this attribute should exchange   *   in *.las or is equivalent to FME_basename.
So each row calls for a file.
Tofia
gio
Forum|alt.badge.img+15
  • Jan 27, 2014 12:35 PM UTC
  • Jan 28, 2014 8:29 AM UTC
Wonderful Gio :)
Now I have a working workbench!
Thank you!
Tofia
