How to run postgresql script (psql -f file_with_sql.sql) in SQL executor
  • Sep 24, 2019 3:45 PM UTC
  • 152 views
I want to run bunch of postgreSQL SQL's through a file using psql command.
To check whether psql works in SQLExecutor, I tried putting below statement SQL executor.
psql -c 'SELECT * FROM testdb.test';
However, I got below error.
psql -c 'SELECT * FROM testdb.test';'): 'ERROR: syntax error at or near "psql"
LINE 3: psql -c 'SELECT * FROM testdb.test;
Can you please help.
  • Sep 24, 2019 3:50 PM UTC
If it's really a psql script you should use the SystemCaller and call the psql command line tool there.
If the script contains regular SQL you can copy/paste the query itself into the SQLExecutor:
select * from testdb.test
Note that it does not include the semi-colon at the end.
erik_jan
Forum|alt.badge.img+26
  • Sep 24, 2019 4:04 PM UTC
If it reads from a table another option would be using the FeatureReader transformer.
You can point that transformer to the table or use the SQL statement to get the records.
