How to replace FeatureReader transformer?
  • Apr 23, 2024 12:41 PM UTC
  • 99 views
marias
Forum|alt.badge.img+11
I need to extract TAB or Shape file from S3 and read data from it including schema.
I have discovered in this article
https://community.safe.com/data-7/how-to-extract-the-actual-shapefile-from-featurereader-geometry-and-attributes-14548?tid=14548&fid=7
that FeatureReader apparently can’t read all attributes that are in the file, until I expose them. But what is I don’t know the list of all attributes? I don’t know what exactly will be uploaded by other people to S3 bucket, I just need to read the file.
Could you help, please, to identify the correct settings of FeatureReader or another way to extract data?
Best answer by liamfez
You could try working with the Schema port on the FeatureReader. That should be able to provide you with the list of attributes if that helps.
liamfez
Forum|alt.badge.img+44
  • May 3, 2024 3:38 PM UTC
