how to remove specific index of coordinates in a line and rebuild the line without this index?
  • May 23, 2024 2:57 PM UTC
  • 5 replies
  • 147 views
soly
Forum|alt.badge.img+3
Hello ,
i would like to remove specific index of a vertex coordinates from a line .then build the line without this vertex .
How could I achieve it ?
my second question :
How could I find which index vertex coordinates so close to next index coordinates ?
then filter it to keep only one of them.
thanks in advance
FME 2021
Best answer by DanAtSafe
@soly The first vertices within tolerance get removed.  This will change the geometry slightly.  Repaired features exit the Repaired port, and those unchanged exit the Passed port.
tomfriedl
Forum|alt.badge.img+14
  • May 23, 2024 3:37 PM UTC
You can use the VertexRemover. It is not necessary to recreate the line.
soly
  • May 23, 2024 6:01 PM UTC
I tried to use vertex remover but it does not work with me .
could u share the parameter in vertex remover ?
How to find which index of coordinate is close to the next index coordinates of vertex ?
DanAtSafe
Forum|alt.badge.img+23
  • May 23, 2024 8:29 PM UTC
Hi @soly You might want to use a GeometryValidator (instead of a VertexRemover) detecting the issue “Duplicate Consecutive Points”; set the tolerance to the minimum allowable distance.
soly
  • May 24, 2024 5:35 AM UTC
@DanAtSafe
You are right .
By using repaired port of geometry validator .
it cancel only the duplicate index ,right ?
without changing any geometry of the line .
is there any other effect on line ?
what are you doing when geometry validator detect duplicate consecutive ,how to fix it ?
use the repaired port or is there other accurate solution ?
thanks a lot
DanAtSafe
  • May 24, 2024 11:16 PM UTC
