How to reference parent directory of $(FME_MF_DIR)?
  • Apr 12, 2018 6:28 PM UTC
  • 154 views
makt
If $(FME_MF_DIR) references "C:/project1/overview/tasks", is there a simple way to reference one directory up, ie: "C:/project1/overview" ? The way I am thinking is to process $(FME_MF_DIR) with some string functions, based on occurrences of the slash - is this the best way forward, or is there is more elegant or simple solution?
Thanks
Best answer by fmelizard
Hi @makt You could use a ParameterFetcher followed by a FilenamePartExtractor to get one directory up as an attribute.
fmelizard
Forum|alt.badge.img+22
  • Apr 12, 2018 8:57 PM UTC
makt
  • Apr 12, 2018 8:59 PM UTC
Thanks Dan,
In the meantime, I also figured out another way via PythonCaller using the syntax seen here: https://stackoverflow.com/questions/2860153/how-do-i-get-the-parent-directory-in-python
fmelizard
  • Apr 12, 2018 9:23 PM UTC
Thanks Dan,
@makt A ParameterFetcher shouldn't be necessary. If you want to reference the up directory throughout the workspace then put your Python code into a private Scripted Python Parameter.
