How to read texts from dwg file which is associated with SHX font
I am having a large set of DWG files in which all the texts are referenced to a native Autocad font file called XARB.SHX, when I try to read it through FME desktop the fme_text_string shows something which is unrecognizable as FME is referring windows fonts.
I am unable to read the autocad (XARB) style applied to the text in dwg file.
It will be very helpful If anyone can suggest me some workaround.
Thanks in advance.
IMRAN
danilo_fme
Forum|alt.badge.img+45
  • April 17, 2018
Hi @imran
Did you try to enable some configuration in Parameters from Reader DWG?
Thanks,
Danilo
jneujens
  • April 17, 2018
Could you share an example of a .shx file?
  • April 18, 2018
Shared the dwg file and font (style) file in Zip
  • April 18, 2018
danilo_fme wrote:
Hi @imran
Thanks,
Danilo
Hi Danilo,
Enabled and checked with everything but nothing worked
danilo_fme
  • April 18, 2018
imran wrote:
Hi Danilo,
Hi @imran
Could share us the file?
Thanks!
  • April 19, 2018
danilo_fme wrote:
Hi @imran
Thanks!
text.dwgxarb.zip
Sharing the DWG file and font (style) file in zip
  • September 20, 2022
I think this issue still not fixed. Also I need a solution for this subject.
JennaKAtSafe
Forum|alt.badge.img+7
Hi @Ömer Seyfettin KAR​, hopefully Andrea's comments on this thread can serve as a workaround
omerseyfettin
Forum|alt.badge.img+8
Hi everyone You can find attached fmx Transformer which convert the most famous Arabic XARAB.SHX and Y-ARAB-1B.SHX fonts to UTF-8 unicode.
