How to read smallworld data by using FME workbench?
Hi All,
I want to see smallworld data in FME workbench using FME reader. Actually i tried the process same as Shape file but it displays Errors.
Best answer by mark2atsafe
There's some information on this page that may help. In short, you do need to install an extra component to read Smallworld. You can get that component from your Smallworld support contacts, or use an alternative component from a company called SBS. The information about both of these solutions is provided on that web page.
Hope this helps
Mark
pratap
Forum|alt.badge.img+11
  • May 4, 2016
http://www.safe.com/training/recorded/ge-smallworl...
This link might help you...
Pratap
mark2atsafe
Forum|alt.badge.img+49
  • May 4, 2016
Hope this helps
Mark
