How to read CSVs from inside multiple Zip files
tim_wood
Forum|alt.badge.img+8
I've been trying to read CSVs from inside Zip files in 2017.0 (did some testing with 2016.1 as well). For example, I have 5 Zip files each containing 1 CSV.
If I try C:\\Folder\\**\\*.csv, FME won't even create the Reader (I get errors like "CSV reader: Failed to open file 'C:\\Folder\\**\\*.csv' for reading. Please ensure that the file exists and you have sufficient privileges to read it").
However, I discovered that if I edit the Source CSV File value in the Reader parameters, and manually set it to C:\\Folder\\*.zip\\*.csv then it works. Select Merge Feature Type to get all the CSVs presented as 1 Feature Type.
Great tip. Some documentation is available to illustrate how to do this with other formats like Shape. You can also use the syntax C:\\Folder\\*.zip\\**\\*.csv, if the zip files are in a nested directory. C:\\Folder\\**\\*.zip will also work, if FME knows what file suffix to expect for that reader.
erik_jan
Forum|alt.badge.img+19
  • April 14, 2017
If the ZIP files only contain CSV files you do not even have to specify the *.csv:
This worked on two ZIP files, each containing a CSV file with 3 rows.
Forum|alt.badge.img+50
This doesn't seem to work with shapefiles that are stored online (https://s3.eu-central-1.amazonaws.com/redgeo-test/Cycling.zip contains 3 shapefiles in the zip root, no problem, https://s3.eu-central-1.amazonaws.com/redgeo-test/Cycling_level2.zip has a subfolder with those 3 shapefiles, can't be read online but can be read if it's stored locally).
Any ideas on that?
