How to read an SDE feature class with fmeobjects in Python?
  • May 28, 2013 11:45 PM UTC
  • 69 views
Does anyone have any examples of reading an SDE feature class with fmeobjects in Python?
I was able to do it with a shapefile without any issue but am having trouble figuring out how and where to specify the parameters for the GEODATABASE_SDE format.
I am using an SDE connection file if that makes it any easier. However, whenever I try to open() the reader it pops up the SDE connection properties dialog. I get the feeling I'm just not specifying the reader parameters/directives correctly, but without finding any examples of the proper format I can only guess.
Thanks!
Best answer by david_r
Hi Logan,
good to see that you fond a solution. One good tip for constructing the connection parameters, is to use the FMEDialog class to let you interactively specify the parameters, then storing the result as a constant in your script for consequtive runs. Example:
dialog = FMEDialog()
directives = dialog.sourcePrompt("SDE30", "sde")
# ... further on ...
reader = FMEUniversalReader("SDE30", False, directives[2])
The sourcePrompt (or destinationPrompt, if you prefer) will give you the same connection dialog as used by the Workbench, returning a connection string that you can use to connect to your data.
David
  • May 30, 2013 7:30 AM UTC
Hi Logan,
David
