How to read a PRJ file in FME Desktop? This format is not in the list of available formats in the Reader. I want to read coordinate system-related data from a PRJ file for reprojection.
  • Jun 16, 2022 11:44 AM UTC
  • 7 replies
  • 356 views
rishi1804
Forum|alt.badge.img+4
@Hans van der Maarel​  @david_r​  @chrisatsafe​  @safesoftware safesoftware​
Forum|alt.badge.img+63
PRJ itself is not a supported format, but if you read the data file it comes with it will use the PRJ to facilitate reprojection.
E.g. if you have a shapefile with a prj, just read the shapefile, FME will automatically pick up the prj.
rishi1804
  • Jun 16, 2022 11:55 AM UTC
Thanks for replying but I don't understand your answer. Actually, I have a file with the .prj extension. I want to read its content. Like here in this tutorial .txt is used https://community.safe.com/s/article/using-external-coordinate-system-names-with-coordi
Learn something new every day, I did not know about the CoordinateSystemDescriptionConverter 😂
In that sample they use a .txt file with a WKT description. In your case the steps may differ slightly. If you open that PRJ file in a text editor like Notepad, what does it look like?
rishi1804
  • Jun 16, 2022 12:02 PM UTC
PROJCS["NAD_1983_StatePlane_Washington_South_FIPS_4602", GEOGCS["GCS_North_American_1983", DATUM["D_North_American_1983", SPHEROID["GRS_1980",6378137.0,298.257222101]
], PRIMEM["Greenwich",0.0], UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"], PARAMETER["False_Easting",500000.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",-120.5],
PARAMETER["Standard_Parallel_1",45.83333333333334],
PARAMETER["Standard_Parallel_2",47.33333333333334],
PARAMETER["Latitude_Of_Origin",45.33333333333334],
UNIT["Meter",1.0],
AUTHORITY["EPSG",32149]
] Like this.
Right, so that is the same structure as in that example. You can use the Text Reader to read the .prj file and then all the other steps should be the same.
rishi1804
  • Jun 16, 2022 12:27 PM UTC
Not working, Maybe the format is different or something else.
rishi1804
  • Jun 16, 2022 12:42 PM UTC
@chrisatsafe​ @keziaatsafe​  can you please help me with this thing?
