How to proper save raster to jpeg-format
  • Mar 2, 2021 5:37 PM UTC
  • 280 views
I'd like to save raster to the JPEG format. The raster includes an alpha band. In order to save to JPEG the alpha band needs to be removed. When the alpha band is there the background appears white in FME Inspector.
When I remove the alpha band the background turns black. That's also the background color when I save the raster to JPEG. How can I work around this problem and make the background white when I save to JPEG?
With the alpha band. White background.
pic1Without the alpha band. The background turns black. I don't want that.
pic2
Best answer by debbiatsafe
Thank you for your quick reply. I noticed something else in the process. The transformer seems to invert colors. Blue turns to red for example. Why is that and how can I avoid it?
Before the transformer
pic3
After the transformerpic4
Hi @henrikandersson​
Your initial screenshot shows your input is a BGRA32 raster (instead of RGBA32). Two of the raster bands were switched when the raster was coerced to RGB24. You should be able to avoid the issue by using a RasterBandOrderer (band list: 2 1 0 3) before the RasterInterpretationCoercer.
debbiatsafe
Forum|alt.badge.img+24
Try using the RasterInterpretationCoercer instead of removing the alpha band. The destination interpretation type parameter should be RGB24--ensure the RGBA to RGB parameter is 'Apply the alpha band'.
pic3
debbiatsafe
  • Mar 3, 2021 8:07 PM UTC
pic3
Thank you. That worked wonders.
