How to pass Excel attributes to a SQL Creator?
  • May 14, 2019 9:50 PM UTC
  • 123 views
I have an Excel spreadsheet where I want to pass several attributes as variables into a SQL Query using a SQL Creator transformer. What is the best way to achieve this? I don't see how I can make the attributes as user parameters.
Best answer by takashi
Why not use the SQLExecutor rather than SQLCreator? You can read the Excel attributes with an Excel reader then use the feature attributes to build a SQL statement in the SQLExecutor.
  • May 14, 2019 10:07 PM UTC
  • May 14, 2019 10:12 PM UTC
That's it! Thanks Takashi. I knew it could be done :-)
