How to format CSV Output
  • Jun 5, 2019 8:54 PM UTC
  • 18 replies
  • 286 views
I am very new to FME. I'm trying to understand how to format where data is placed within my CSV output. I'm reading specific elements in an XML file and writting it as a CSV. I almost have it working, however it is writting it in the below format.
How to I fix the formatting so that the values fit on the same rows, eliminating the blank spaces?
jdh
Forum|alt.badge.img+41
  • Jun 5, 2019 9:02 PM UTC
It looks like you are exploding (fragmenting) each element of your xml into a separate feature, rather than flattening them.
If you inspect the features just before the writer do you have 20 of them, or just 4?
  • Jun 5, 2019 9:10 PM UTC
Like i said, i'm new to FME, so i'm not yet comfortable with the lingo. Does this photo help?
jdh
  • Jun 5, 2019 9:14 PM UTC
Ideally you could post a fragment of your xml structure, on the xml reader itself the parameters of interest are 'elements to match' and 'flatten options', but without knowing the structure of the xml it's hard to make recommendations.
  • Jun 5, 2019 9:38 PM UTC
Here's a what i typed into "elements to match"
and here is a sample of my XML file
jdh
  • Jun 5, 2019 9:50 PM UTC
What you want in your elements to match is simply "log"
Enable flattening and you should end up with one feature per log, with the date, time and channel attributes you want.
  • Jun 6, 2019 12:52 AM UTC
Awesome! It worked! thank you very much. There's only one more problem, sometimes the XML files are formated this way with no indenting:
When i run these files, i get the following errors;
  • Jun 6, 2019 1:29 AM UTC
The XML parser should parse XML documents regardless of whether it has indentations or not. I don't think that missing indentations causes the error.
According to the error message you have posted, there seems to be an invalid character in the line 43. I guess that the encoding declaration in the XML header may be missing or may not match the actual encoding of the XML documentation.
Check if the XML header (the first row of the document) matches the actual encoding.
  • Jun 6, 2019 1:48 AM UTC
everything matches. I have a degree symbol in line 43 (for both types of XML files), and it seems to not like it in the above "non-indented" XML file
  • Jun 6, 2019 7:32 AM UTC
Can you share a sample XML file that reproduces the error?
  • Jun 6, 2019 12:44 PM UTC
Issue File.txti had to upload as text file
  • Jun 6, 2019 1:49 PM UTC
Thanks for sharing the sample XML file.
The error is caused by that the XML document has been created with ANSI encoding (non-standard for XML), whereas the XML declaration doesn't contain a correct encoding attribute.
Try specifying the correct encoding explicitly in the XML declaration (the first row), as in:
<?xml version="1.0" encoding="ISO-8859-1"?>
or
<?xml version="1.0" encoding="windows-1252"?>
See also here: How XML deals with different character sets
or
  • Jun 6, 2019 2:01 PM UTC
or
The first row is exactly the same for the files that I do not have any issues with?
 Also, i'll be working with thousands of files, is there a way to change this declaration within FME?
  • Jun 6, 2019 2:49 PM UTC
I guess that the files you were able to read without error [1] don't contain any invalid characters like the degrees symbol fortunately, or [2] are created with UTF-8 encoding.
Anyway, for the files raising the error, a possible workaround is:
  1. Use a Text File reader to read the entire document at once with specifying the correct encoding.
  2. Change the encoding to UTF-8 (XML standard) with the AttributeEncoder.
  3. Parse and flatten the XML with the XMLFragmenter.
  • Jun 6, 2019 7:26 PM UTC
This did not work either. It's odd because the other files have a degree symbol as well and it works just fine.
  • Jun 6, 2019 9:25 PM UTC
Do you mind sending me a template with a CSV writter? I've been at this all day and still cant figure it out.
  • Jun 6, 2019 10:29 PM UTC
What error appeared?
nielsgerrits
Forum|alt.badge.img+67
Learned something new today, thanks!
