How to fill up the item description of the new feature class in gdb?
wind
Hello,
I create the feature class il a gdb automatically every night. I need to fill up the item description in the same time.
Thank you
Best regards
Best answer by david_r
It doesn't have to be an XML workspace document, you can also use a File Geodatabase as a template:
  • November 20, 2018
If the output structure is always the same, have you considered using a pre-filled template?
https://knowledge.safe.com/articles/40193/how-to-use-an-esri-template.html
wind
  • November 22, 2018
I have no necessary licence for the creator of XML templates in ArcMap.
Thank you very much anyway.
  • November 22, 2018
