How to extract polygons from shp to csv file
  • Jul 10, 2017 11:50 PM UTC
  • 147 views
Best answer by erik_jan
You can use the GeometryExtractor transformer to create an attribute holding the polygon definition (choice of multiple formats, but WKT is often used).
  • Jul 11, 2017 12:38 AM UTC
Hi @jitkam, it depends on your desired CSV table schema. For example, how do you want to describe this polygon feature (having 3 user attributes - attr1, attr2, attr3, and a single polygon geometry with 5 vertices) in the destination CSV table?
Attribute(string)             : `SHAPE_GEOMETRY' has value `shape_polygon'
Attribute(encoded: fme-system): `attr1' has value `aaa'
Attribute(encoded: fme-system): `attr2' has value `bbb'
Attribute(encoded: fme-system): `attr3' has value `ccc'
Attribute(string)             : `fme_feature_type' has value `data'
Attribute(string)             : `fme_geometry' has value `fme_polygon'
Attribute(entangled: string)  : `fme_type' has value `fme_area'
          entangled to [SHAPE_GEOMETRY]
Coordinate System: `'
Geometry Type: IFMEPolygon
Boundary:
   Geometry Type: IFMELine
   Number of Coordinates: 5 -- Coordinate Dimension: 2
   (0,0)(0,2)(3,2)(3,0)(0,0)
  • Jul 11, 2017 4:48 PM UTC
Boundary:
Hi @takashi, thank you for your comment. I have an shp file with postal codes and I need to convert to csv to have a postal code and a single polygon with each. Taking the shp file as writer and csv as reader without any other elements will only provide me with list of postal codes in the csv right now, so I need to find a way to also add polygons.
erik_jan
Forum|alt.badge.img+26
  • Jul 11, 2017 5:11 PM UTC
  • Jul 11, 2017 5:38 PM UTC
Thank you @erik_jan
