Hi all, i know it will maybe an easy one….I’ve tried with substringextractor or with AttributeTrimmer as well but i couldnt reach the right result.
i have attribute like these for example:
he0_wasser_WSG_TK_20143_AGE_f_r01_231030 or ni0_geobasisdaten_gemischte_industrie_gewerbe_flaechen_20256_AGE_f_r01_240118
i have to split in this case “he0” and “ni0” and write that in an attribute x i have to split “wasser” and “geobasisdaten” and write that in an attribute y
i have to split “AGE” in an attribute…….and so on
now comes the challenge: the text between “wasser” or “geobasidaten” and the 5digit number (20143, 20256) has sometimes 2 words, sometimes 3 or 5 words…..but i have to write the whole text in an attribute z….ho can i do that?
i am not so well in regexp…..so i ask here for help
Thank you
Cheers
Franco
Best answer by franco69
joepk wrote:
I would avoid intricate RegEx expressions. They are hard to debug and they do not work the same in every environment.
I have solved this using the following native tools:
AttributeSplitter splits attribute and puts every part between the underscores in a list item.
ListSearcher searches the list using RegEx for 5 digits and returns 5_digit_number_index.
ListExploder explodes list.
Tester filters out the first two elements (index 0 and 1) and all the elements that share the same index or higher as the 5_digit_number_index.
Aggregator (grouped by ID) aggregates all list features together and creates a new list (Generate List: z_list).
Finally the ListConcatenator creates the output string of all string elements between the first two elements and the 5 digit number.
That do the work for me….thank you….but the listconcatenator is not necessary because to concatenate the attributes inside the aggregator also do the work
hmmm…..list was created but not right…….. fme_feature_type is the attribute to split
listname 0 is ok listname 1 also ok listname 2 should be Fliessgewaesser……….here in this case is only one word between second underscore and the 5 digit number (but there could also be 3 or 4 words)
listname 3 should be 20240 (is now listname 3) listname 4 should be AGE (is now listname 4) and so on
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
