How to export DataTypes of an input file
  • Aug 13, 2013 6:46 AM UTC
  • 68 views
Hello,
maybe my question has an simple answer, but I can't find a way to solve this problem. Is there any possibility to read out the data types of an input-file?
For example: A shape-file with three attributes: Name --> char, Adress --> char, Number --> int. I need the data types (char, char, int) in a FME-List or something like that. Finally I want to write them in a simple Excel-Sheet.
I'm using FME 2011.
Any help would be appreciated.
Thanks,
Hans000
fmelizard
Forum|alt.badge.img+22
  • Aug 13, 2013 7:26 AM UTC
Hi Hans,
The Schema any format reader will provide you with that information.
Itay
  • Aug 13, 2013 8:25 AM UTC
Hi Itay,
thanks for the answer. That was too easy, but I never used the schema reader before.
Thanks,
Hans
fmelizard
  • Aug 14, 2013 10:04 AM UTC
Hi Hans,
Its only easy when you know what to look for :)
