How to execute multiple sql query statements in an SQL Creator in FME?
  • Feb 22, 2019 4:24 PM UTC
  • 6 replies
  • 523 views
I am running a following script,
set serveroutput on;
DECLARE
message varchar2(20):= 'Hello, World!';
BEGIN dbms_output.put_line(message);
END;
Its throwing error for set serveroutput on. If I remove that statement query runs successfully with no results returned from oracle db.
  • Feb 22, 2019 4:25 PM UTC
@SteveAtSafe
  • Feb 22, 2019 4:33 PM UTC
I'm not sure what you want to accomplish, but this is expected behavior:
  • the command "set" is not SQL, it's a command that only has a meaning within the Oracle "SQL*Plus" tool, where it's used to configure the client behavior.
  • dbms_output is for sending messages to the Oracle console, not to generate data. FME does not support dbms_output messages.
Please tell us what you need, then perhaps we can point you in the right direction.
  • Feb 22, 2019 5:25 PM UTC
I am trying to run a plsql script from SQL Creator(SQL statement) in FME. I have connected to my oracle db with connection in SQL Creator as Oracle spatial object.
My script looks like (Can't post the entire script),
declare
var1 er1;
curr_dev varchar2(100);
several variables declared here..
begin
some code ...here
-- Finally get the output
DBMS_OUTPUT.PUT_LINE('Total number of fibers : ' || fibersCount);
DBMS_OUTPUT.PUT_LINE('Total number of fibers with Pencil Filter : ' || fibersWithPencilFilter );
DBMS_OUTPUT.PUT_LINE('% of fibers with Pencil Filter : ' || Round(fibersWithPencilFilter * 1.0/fibersCount,3) || ' %' );
end;
After running this code, I get an error ->
An error occurred while accessing a table result for feature type `';
message was `Execution of statement `SET SERVEROUTPUT ON;
BEGIN [entire code] END;' did not succeed; error was `ORA-00922: missing or invalid option'.
Is there any other alternative for this> How can I get the results from oracle database into FME.
  • Feb 22, 2019 5:32 PM UTC
Please guide me for an alternative way to get results into FME from Oracle? Do I need to change my script?
  • Feb 25, 2019 9:15 AM UTC
You cannot execeute PL SQL in FME, only regular SQL.
There is more information about the differences between PL SQL and SQL here: https://www.guru99.com/sql-vs-pl-sql.html
So basically your only solution is to rewrite your script as regular SQL. If the script contains logic that cannot be directly implemented in SQL, you can probably achieve the same thing using one or several SQLExecutors in conjunction with FME transformers such as the Tester etc.
  • Feb 28, 2019 9:03 PM UTC
Thank you @david_r. This was really helpful. Now I have a clear direction.
