How to emulate the "Create Routes" tool from ArcGIS?
  • Jul 26, 2024 8:17 AM UTC
  • 179 views
aric5
Participant
I have three lines coming from CAD, I have read them and I would like to use “Create Routes”, instead I have used the measure generator. However, the measurements are wrong, and I suppose because on the way the vertices of the line were drawn (in an illogical order).
By using “Create Routes” I could select the coordinate priority (lower left, lower right, upper left, upper right) to tell it to start counting from that point onwards (because the coordinate priority will be different per line). Is there a way that the same can be done in FME?
Thanks!
donalmateer
Forum|alt.badge.img+13
Hi @aric5
Thank you for the question.
I have found several articles that may be of benefit to you and may point you in the right direction.
Building a Topological Network from a Road Dataset | Using the TopologyBuilder
Shortest Route Calculations with the ShortestPathFinder.
This question also has some overlap and the answer provided may help.
Please let me know if you still need assistance after reviewing the links - I will gladly assist.
Thank you!
Donal.
