,How to covert from fbx file to citygml file, Which is got export from infraworks????
  • May 29, 2017 12:44 PM UTC
  • 131 views
I got exported FBX file from INFRA WORKS 360 with actual coordinates system, but when i got convert that file into citygml by using fme that coordinates value change to LOCAL values, Even I did inspect of the reader file .fbx its on local coordinates value. My question is How to read the fbx file with actual coordinates system by suing fme
Note: I have supporting file for fbx is .pos file, In FME there is no option to add the .pos file while using the reader for FBX....
  • Jul 2, 2019 2:00 PM UTC
Hi I don't know if it will help but I got a similar problem with coordinates. It was not related with FME but with the export from Infraworks :
