How to convert 2D pipeline (shapefile or Esri File Geodatabase) to 3D pipeline
  • Oct 29, 2019 2:24 PM UTC
  • 7 replies
  • 141 views
Hello, I want to convert 2D pipeline(shapefile or Esri File Geodatabase) to 3D pipleline to put it into cesium,Do you have any idea?Thanks
jdh
Forum|alt.badge.img+41
  • Oct 29, 2019 2:48 PM UTC
What sort of information do you have in regards to the elevation of the pipelines?
  • Oct 30, 2019 12:52 AM UTC
I have 3 fields to store the pipelines's elevation
jdh
  • Oct 30, 2019 12:34 PM UTC
I meant, is each pipeline a constant z, or do you have a z value for each vertex, or do you have certain z values, and the others need to be interpolated.
If any of the that, is it an absolute elevation or a height (depth) relative to the ground surface?
Is this information stored in an attribute on the feature or is coming from an ancillary dataset?
Thanks for your replying,my pipe data has two feature layers(table),a point layer and a polyline layer.Each pipeline has only two vertexes and the vertext's information is in the point layer(x,y,elevation.etc.),the line has no elevation information just some name,length,projectname property etc.my pipe has no Z value but if needed,i can have the Z value. The elevation in the point layer has 3 types,include absolute elevation and the relative.
jdh
  • Oct 31, 2019 1:55 PM UTC
You can use a spatialRelator to transfer the elevation attributes from the points to the polylines.
Then use a 3DInterpolator on the polylines, setting the Starting and Ending Elevation to the attributes transferred from the points.
mark2atsafe
Forum|alt.badge.img+59
If you want your pipelines to be solid (i.e. not just zero-width lines but actually matching the diameter of the pipeline) then you can use the Bufferer transformer.
Set the buffer type to solid and enter the pipe radius.
Here's an example of a subway line buffered to 25 metres:
becchr
Forum|alt.badge.img+35
  • Oct 31, 2019 9:33 PM UTC
I think, if i understand your question well, there was this similar question last week with several approaches to solve this issue
https://knowledge.safe.com/questions/101146/help-2d-lines-to-3d-using-some-known-3d-points.html
