How I can run two procedure after write
  • Dec 28, 2018 8:28 AM UTC
  • 57 views
How I can run two procedure after write using this option.
danilo_fme
Forum|alt.badge.img+58
  • Dec 28, 2018 12:12 PM UTC
Hi @bkolubenka
Did you try to insert your procedure in the option: SQL to Run After Write ?
Thanks,
Danilo
erik_jan
Forum|alt.badge.img+26
  • Dec 28, 2018 2:40 PM UTC
I would use the FeatureWriter instead of a writer.
Then connect a SQLExecutor to an output port of the FeatureWriter to execute any SQL.
