How do I upload shapefiles to FME Server?
  • Jan 22, 2020 7:54 PM UTC
  • 244 views
I have built a workbench that takes a shapefile (which isn't one file) as an input. I've published it to FME Server. How do I upload a shapefile(s) so that FME Server will process it?
Best answer by erik_jan
You can Zip the files and upload the Zip file.
FME can read those as being a Shape file collection.
Hope this helps.
erik_jan
Forum|alt.badge.img+26
  • Jan 22, 2020 7:58 PM UTC
Hope this helps.
HI @deanrother,
If you are uploading the source dataset at run time the other option is under the 'Temporary Uploads' tab upload all files, then under the Selected Items header on the right-hand side remove all the files apart from the .shp extension:
  • Jan 22, 2020 10:28 PM UTC
The zip file upload seemed to only work sporadically until I replaced the Shapefile reader with a dynamic reader. Hence my confusion despite attempting both suggestions prior to posting. You pointed me in the right direction.
