How do I set my writer to override existing file?
  • Mar 31, 2016 5:49 PM UTC
  • 686 views
Lets say I have a routine with a writer and I run it. Now I want to run the same routine without having to change the writer file name. I want it to delete the old file and create a new one or Override the old file. How do I change the settings in the writer to do this?
erik_jan
Forum|alt.badge.img+26
  • Mar 31, 2016 5:52 PM UTC
This depends on the writer you are using.
Default setting for most file based writers is to overwrite any existing file.
Some writers have a setting to either overwrite or append to a file.
Some files can not be overwritten if opened by another application (XLS, PDF and maybe others).
  • Mar 31, 2016 6:39 PM UTC
If by any chance it is a geodatabase, then you can set the option of Overwrite Database to Yes when you first add a writer.
