How do I read .trk files into FME?
  • Jul 5, 2023 7:26 PM UTC
  • 85 views
ravibansal
Forum|alt.badge.img+5
I am looking to rewrite a process to use FME instead of SSIS. The process reads data from .trk files. But I am not able to find any reader for .trk files in FME. Please suggest.
hkingsbury
Forum|alt.badge.img+73
  • Jul 5, 2023 7:34 PM UTC
If you open the file in notepad, does it contain a bunch of text that makes sense? or is it a bunch or garbage? If its the former, then you can use a text file reader to read the data in then begin to parse it, if its the later, then you're out of luck.
Is there an example file you're able to share?
