How do I read the Global Width on lines and polylines from a DWG-file?
  • February 3, 2020
  • 88 views
gabriel_hirsch
Forum|alt.badge.img+12
How do I retrieve the setting for Global Width on the geometries?
gabriel_hirsch
  • February 3, 2020
I answer myself so others don't have to spend time looking for the answer.
The AutoCAD Global Width setting is stored in the autocad_width attribute in FME. If the advanced reader parameter "Stora Bulge Info" is turned on you can retrieve the attributes autocad_start_width and autocad_end_width if they differ from the Global Width.
