Hi, I'm trying to mine edits in a GDB with only a DEFAULT version. The ArcSDE GDB reader seems set up to compare differences between parent-child versions. I want to compare edits within the DEFAULT version only. I can do this using a DBMS reader and working with the A and D tables but it would be way easier to use the native reader, however setting the baseline and transaction versions both to DEFAULT returns no features ;-(. BTW the comparison business rule is between edit dates from editor tracking fields.
