How Do I Fetch the Largest Value of an Attibute, add 1, and Use It as Primary Key..
  • Apr 27, 2015 6:14 PM UTC
  • 58 views
I need to build a list of new records that have the NEXT value for an alphanumeric primary key attribute. Thus, I need to fetch the largest value ( in the form 'ADR000xxxxxxx' where "xxxxxx' is a strictly ascending list of non-zero intergers) from one feature class and populate another (temporary) feature class starting with *that* value +1 .
Thus, let's say my ADDRESS feature class has the largetst MXADDRESSCODE = 'ADR000521327'
And I need to create, for instance, 4 more records. So I need to fetch the above 'ADR000521327', add one to the first, making it 'ADR000521328' and continue with 'ADR000521329, 'ADR000521330, etc. in my temporary feature class named ADDR_WORK.
I have looked at Sorter, ExpressionEvaluator, AttributeFilter, StringConcatenator, and others, but just can't seem to turn the corner on this one.
Thanks
  • Apr 27, 2015 11:09 PM UTC
Hope this procedure works as expected.
(1) Select a feature which has the maximum ADRESSCODE with a Sorter (Order: Descending of ADRESSCODE) and a Sampler (Sampling Type: First N Features, Sampling Amount: 1).
(2) Extract integer number part from the value with a SubstringExtractor (Start Index: 3, End Index: -1).
(3) Create the required number of copies of the feature with a Cloner. The Copy Number Attribute called "_copynum" by default will store 0-based sequential number.
(4) Add (@Value(_copynum)+1) to the value with an ExpressionEvaluator.
(5) Restore the original format ("ADRxxxxxxxxx") with a StringFormatter and a StringConcatenator.
Takashi
