How do I expose the KML placemark attributes?
How do I expose the KML placemark attributes using fme?
Here is the file I want to use:
Best answer by danilo_fme
Hi @rdcrawford
You can expose these attributes on feature type Placemarks:
After select the Attributes in Format Attributes:
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+45
  • May 15, 2018
Hi @rdcrawford
Thanks,
Danilo
Forum|alt.badge.img+50
danilo_fme wrote:
Hi @rdcrawford
Thanks,
Danilo
In addition to that you can use an AttributeExposer transformer. I personally prefer that way in the interest of long-term maintainability of the workspace. If I open it after a few months I'll see that I've exposed attributes. If I don't use the AttributeExposer I might forget that. Same thing goes for when others have to edit the workspace.
