How do I connect to a Microsoft SQL Server database using an Active Directory service account?
  • Feb 19, 2019 2:53 PM UTC
  • 224 views
The SQL Server database I'm connecting to won't support database authentication (policy), so I got a AD service account created, but I can't find an option where I can use Windows Authentication, but I can still enter in the credentials (they are greyed out when you choose Windows Authentication).
FYI: I'm using FME 2018.1
The Active Directory Authentication uses your current windows user account, so the user a password are disabled in the connection parameters. FME SQL Server reader/writer help - see under Authentication
