How do I add attributes to AutoCAD Blocks
  • November 16, 2016
  • 81 views
diwanicka
Forum|alt.badge.img+4
I am trying to write attributes for tree locations to a block I have created using a template with the DWGStyler. Do I need to first specify those attributes in the block template or is it possible to write the attributes to the Blocks when I write the new DWG?
itay
Forum|alt.badge.img+17
  • November 16, 2016
I would suggest adding them to the template, so that you always adapt your template ( which is easier to manage and remember)
todd_davis
Forum|alt.badge.img+22
  • November 17, 2016
If you want it for the whole dwg (i.e. all are blocks that have attributes, you can set the output dwg to use "Inserts"
If its just a single layer within the dwg, you can expose a format parameter (autocad_entity) in the output featuretype and pass it the value "autocad_insert"
alanaliberti
  • August 30, 2018
Is it possible to fill in the block attributes as well? How should I proceed?
