How could export only specific area and the intersected of this area direct from oracle reader
  • Apr 6, 2020 10:10 AM UTC
  • 59 views
gogopotter90
Forum|alt.badge.img+14
i have reader oracle spatial and i would like to export only specific area and the intersected of this area only .
i do not want to export all areas from oracle reader because it spends too much time
so i would like to export the interested areas only from oracle .
i did already spatial filter after that and it works great but the problem it takes too much time to export all areas then execute spatial filter so is it possible to write code inside where clause and as a result as give me rrequired areas without upload all areas .
Thanks alot
Forum|alt.badge.img+63
I you use the FeatureReader you can have it read only the features that fall within an Initiator feature.
gogopotter90
  • Apr 6, 2020 10:16 AM UTC
thanks i was confused about something ,u r right
