How connect to styles in MS Word?
peteralstorp
Forum|alt.badge.img+8
 I have a base word document I want to use and set so I use styles from this base file in the MSWordStyler. But I get error msg when I try to use for instance the style "Tyréns - Brödtext". Tips? Tricks? Partytricks?
The styles as viewed in Word.
Untitled
Kind regards, Peter
Best answer by kailinatsafe
Hello @peteralstorp​ (Tyréns AB), unfortunately the MSWordStyler is limited to using the preset styles available from the Style picker. You could try to use the information provided in the tooltip to mimic the style you desire. Best, Kailin.
kailinatsafe
Forum|alt.badge.img+24
peteralstorp
Ah, ok, @kailinatsafe​ Thanks for your answer! I will have to solve it in some other way then.
bjarne
Forum|alt.badge.img+5
  • December 23, 2020
Hi, have you tried to set the format attribute "msword_font_name" to your preferred font? I think you have to use a custom "Base microsoft Word File" as well. According to my testing, I was able to make a custom "msword_table_style" with a special font.
