How can I write (smart) XYZ from table with multiple Z fields
  • Aug 5, 2019 2:36 PM UTC
  • 97 views
cyrusa
Forum|alt.badge.img+8
Hi all,
I have a table with (XYZ) coordinates measured in time. Each time the Z-value (field J and further) of the specific point changes. The XY-coordinates (field E and F) stay the same. Sometimes the Z-value is missing.
How can I project all of these point without manual adjustments to the table? So for the second row we have:
  • 1st measurement: X=94439,5, Y=435795,0 and Z=-0,80370
  • 2th measurement: X=94439,5, Y=435795,0 and Z=-0,80500
  • 3th measurement: X=94439,5, Y=435795,0 and Z=-0,80600
  • 4th measurement: X=94439,5, Y=435795,0 and Z= missing here so no projection
  • and so further on
In the end I want to have a geodatabase.
Many thanks for you reply!
Alan
Best answer by itsmatt
Hi @cyrusa,
This is where lists can be of use. You can use the following as a guide to create x,y,z points where z values are present.
itsmatt
Forum|alt.badge.img+48
  • Aug 5, 2019 3:52 PM UTC
Hi @cyrusa,
cyrusa
  • Aug 5, 2019 8:09 PM UTC
Hi @virtualcitymatt,
Thanks a lot for your quick reply and guide to the solution. I tried and it worked for me! Thanks.
I will try to get the field names also as an attribute to the table.
Cheers!
