How Can I write in a Smallworld DB field, with an associate catalog?
jalejandroruizc
Hello, I am trying to write to a Smallworld DB, in a required field (Nominal Diameter) associated with a catalog and I get the following errors:
"Smallworld Translator Error: The '4' value of Nominal Diameter field does not map to an entry in the Main Catalog catalog.
Smallworld Translator Error: The '3' value of Nominal Diameter field does not map to an entry in the Main Catalog catalog.
Smallworld Translator Error: The '2' value of Nominal Diameter field does not map to an entry in the Main Catalog catalog".
Those values are present in the catalog, but the writer cannot find them.
Any recommendation to use Smallworld catalogs?
Thanks in advance,
Jesus Alejandro Ruiz.
@jalejandroruizc I think you need to use the descriptive value, not the coded domain value. That might have changed, but worth trying.
jalejandroruizc
Thank You.
Best Regards.
