How can I temporarily limit the number of records that I'm reading from an ArcGIS feature layer?
  • Jan 12, 2022 2:01 AM UTC
  • 8 replies
  • 376 views
datablue
Forum|alt.badge.img+11
I'm trying to speed up the processing speed. There might be a few different ways to do this. I'm trying to make incremental changes to a workspace and every time I run it, it takes about 40 seconds.
I have two tables in ArcGIS and I use a FeatureJoiner to join them in FME. One of the tables has a data field. I'd like to only process a range of dates. I have about 8,000 records total and I'd like to limit it to 1,000 or so records. Once I get my workspace functioning correctly, I'd like to remove this date range limit. I'm very new to FME.
Best answer by nielsgerrits
You probably can do this using the where clause in the reader.
What do you use to read the data? A classic reader or a FeatureReader?
Which type of reader? Esri ArcGIS Server Feature Service?
nielsgerrits
Forum|alt.badge.img+67
  • Jan 12, 2022 9:01 AM UTC
Forum|alt.badge.img+54
  • Jan 12, 2022 9:38 AM UTC
You should be able to do this under the reader parameters in the navigator
nielsgerrits
That was my initial thought as well, but he wants to read a specific date range.
datablue
  • Jan 12, 2022 6:24 PM UTC
Thanks for your response. The reader type shows: Esri ArcGIS Online (AGOL) Feature Service. When I double click on it, I see the Where clause in the Parameters tab. It looks straight forward. I'll try to fill it out now. I'm now thinking that I can use the objectid.
I have two tables, each with a reader. The first table is for locations and the second table is for people. They have a one-to-many relationship: Locations -> People (each location can have one or more persons).
I think that I can specify that objectid needs to be greater than a certain number which could give me the last X number of records. Or, perhaps I can specify a range. I'll give this a try. I suspect that I will need to specify a where clause on the reader for the second table as well.
datablue
  • Jan 12, 2022 7:20 PM UTC
As I mentioned, I have two tables, each with a reader. The first table is for locations and the second table is for people. They have a one-to-many relationship: Locations -> People (each location can have one or more persons).
I added a where clause for each reader.
Locations table: "objectid" BETWEEN 23277 AND 23528
People table: "objectid" BETWEEN 4424 AND 4684
Now, I'm processing a few hundred records instead of about 8000. The processing time is a few seconds instead of about 40 seconds. Now I can incrementally change my workspace. When I have everything working correctly, I'll remove the Where clause.
I couldn't figure out how to filter on the date mostly because only the Locations table had a date and I needed a where clause on both tables/readers. Thanks for everyone's help. This was my first question.
mark2atsafe
Forum|alt.badge.img+59
You might be new to FME but you're spot on in restricting the input while you develop the workspace. That's a good call.
Another way to help would be to use Feature Caching (the Cache button on the toolbar). It takes a bit longer on the first run, but after that, you only need to run the workspace on changes that you make. All existing readers/transformers that don't change have a cache of the data at that stage of the process, which is quicker than re-processing it.
datablue
  • Jan 20, 2022 10:52 PM UTC
Thanks for the tip. I have recently started making use of caching. I how hovering the mouse over the Run button shows the readers/transformer that will update. (I don't see a Cache button on the toolbar, but maybe I'm looking in the wrong place.)
For this particular situation, I'm glad that I was able to restrict the input using a where clause in the reader. I had 8,000+ records and limited the input to a few hundred records.
This is helpful, thanks for sharing.
